 Norton Commando 961 SE... Rhaaa LOVELY !!!
MessageSujet: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 0:41
Tarif : 19000 €
FRAME
Frame: Steel tubular cradle with integral oil tank
Swing arm: steel construction
Wheelbase: 1420mm (55.9 in)
Rake: 24.5 degrees
Trail: 99mm (3.9 in)
Front suspension: 43mm Ohlins RWU - Adjustable preload, compression, and rebound damping.
Rear suspension: Ohlins reservoir-style twin shocks - Adjustable ride height, preload, compression, and rebound damping.
Front wheel: 3.50 X 17" BST Carbon Fibre
Rear wheel: 5.50 X 17" BST Carbon Fibre
Front tire: 120/70 X 17"
Rear tire: 180/55 X 17"
Front wheel travel: 115mm (4.53 in)
Rear wheel travel: 100mm (3.94)
BRAKES & HYDRAULICS
Brembo 320mm semi-floating hi carbon stainless steel front discs
Brembo 220mm rear disc
Brembo 4 piston "Gold Line" axially mounted front callipers
Brembo 2 piston "Gold Line" rear calliper
Brembo “Gold line” front brake master cylinder
Brembo “Gold line” hydraulic clutch master cylinder
Brembo rear brake master cylinder
Brembo hydraulic clutch actuation slave cylinder
POWER ASSEMBLY
Engine type: Parallel twin with push-rod valve actuation, dry sump
Displacement: 961 cc
Cooling system: Air
Valve Actuation: Push rod, hydraulic lifter, two valves per cylinder
Bore x stroke: 88 mm X 79 mm
Compression ratio: 10.1:1
Power: 80PS @ 6500RPM
Torque: 90Nm @ 5200RPM
Exhaust:1 3/4" header system with merged collector and twin silencers with catalytic converters.
Ignition: Crank fired electronic
Euro 3 compliant with electronic fuel injection and multiple 3 way catalytic converters
CARBON PACK
Front mudguard
Chain guard
Rear wheel hugger
Rear number plate hanger
Headlight mounting
Front wheel
Rear wheel
TRANSMISSION
Gearbox: constant mesh 5 speed
Final drive: 525 "O" ring chain
Wet clutch
Electric start
ELECTRONICS & CONTROLS
Charging system: 300 watt hi-output charging system
Instrumentation: Norton electronic analogue speedo and tachometer with dual trip meters and ‘hidden until lit’ warning lights
MISCELLANEOUS
Fuel tank capacity: 17l (4.5 US gallon)
Dry weight: 188kg (414.5 lbs)
Seat height: 813mm (32 in)
Billet machined upper yoke
Billet machined lower yoke
Tapered aluminium handle bars
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 0:57
très très belle
la dernière est une série spéciale HUMHUM
elle a une fourche inversée, des bracelets un saut vent...
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 1:05
Ah oui tiens je n'ai pas remarqué ! lol! pourtant la serie speciale, cest la noire ! study
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 1:07
Doit y avoir deux modeles en fait : la 961 et la 952
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 1:15
jeremy29800
Modèle MOTO: hayabusa 2004
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 8:02
magnifique....
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 8:54
super parti cycle imagine la meme avec un moteur de BM un flat... le reve
chris85
10000/0  (10000/0)
Modèle MOTO: 1340gsxr
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 9:03
sa fait du bien ,j'adore
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 9:08
En tout cas de celles la, yen a pas sur le bon coin a essayer !!! lol!
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 10:32
c'est beau c'est le prix qui craint dommage
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 11:06
sympa la vidéo
bandy
Modèle MOTO: Y noir et grise
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 12:47
elle est vraiement super cette becane et quel myth aussi
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 12:53
Mon premier coup de coeur comme cela c'est la Black .....elle a quelque chose qui accroche le regard....
Jolie vidèo avec la zic qui va bien....
Merci pour ce partage....
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Dim 15 Avr - 19:20
très belle moto,la vidéo
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 16:00
oui belle bécane, belle finition, au niveau conduite quelqu'un a essayé?
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 17:51
Fabuleux !
Je ne crois pas que ce genre de chignole puisse faire l'objet d'un essai, c'est comme une Femme elle te plait tu craques et Paf t'es indessoudable !
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 18:00
oui je me vois avec en un une haya, en deux vfr, et en trois cette norton ma femme pète les plombs quand je lui sors un truc pareil en tout cas je lui ai déjà annoncé que je reprend le travail en 2013, deux mois après je commence la recherche d'une orange
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 18:10
T'inquiète Alain, une femme il ne faut pas qu'elle puisse s'ennuyer… Crois moi si tu lui en ramène 3 chignoles, Ha, ha, ha, elle ne risque plus de s’ennuyer, non car elle va te montré ce qu’es un prof de gym en te courant après ha, ha, ha, n’attends plus... Mets ton casque maintenant ! Et raconte moi
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 18:36
oui elle a commencé à me du regard mais j'ai joué mon convalescent nous verrons tout celà en temps voulu
Blackbusa
20000/0  (20000/0)
Modèle MOTO: K6=>Pan European=> ?
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 19:00
Moins chère et pas trop éloigné, Ducat 1000 GT ou Sport Classic au choix.
Léger, coupleux et c'est une Ducat ! uuummbrarr, ummbrarrr !!
J'avais lorgné dessus en phase réflectatoire pré-Buse.
C'est pas cher, fiable et les intervalles d'entretien ont été rallongés.
On en voit pas beaucoup, mais j'en ai justement vu une hier soir avec des Termignoni (la marque des Ducat).
Je vous met le lien vers la 750 SS Imola, pour le bruit et parce qu'elle est la plus emblématique de la marque : http://www.youtube.com/watch?v=YTnxAsHnTQQ&feature=related
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 19:17
MessageSujet: Re: Norton Commando 961 SE... Rhaaa LOVELY !!!    Sam 21 Avr - 19:31
oui magnifique avec la selle confort
